Your database was clean and almost up-to-date though it did create 16 indexes.
Hi, First issue all day.
Total light NaNh
I saw this on my display from yesterday. I think I have it fixed and will make sure in two hours.
I found and fixed the issue. New files have been uploaded.
Some detail changes and a sample of what a high pressure reading looks like. It feels like my location as dropped 1200 feet in altitude. I can breathe.
I have a new version ready to test if anyone has time to watch their system for errors. If you want to try it, please PM me and I’ll give you the link.
No time tonite but I’ll test tomorrow. I’ll pm then.
Hi, Chuck,
The Total light value is fixed.
On another note, I am finally understanding Air Density and Altitude Density in what causes it to change. The effective altitude is 3000 feet less then normal. Now I understand why I breathe better in cold, dry weather.
I want WeatherFlow to create a series of videos that explain how temperature and humidity and air pressure work together. Maybe some of us will actually learn about weather.
I like it!
Sure, will try tomorrow eve.
tonight when I come back from work, to little time left before leaving
I was confused by the “Altitude” title until I read a little further. Pilots use the term Density Altitude. I think this is what you are actually referring too. I believe this is the effective altitude when the sea level pressure is 29.97inHg, at least that I what I recall from flying with my dad and brother.
Yes.
Maybe I should re-title it to:
Density: Air
Altitude
This application was designed solely for intranet use, however by port forwarding from your router it works perfectly well on an Internet connection.
I received a request to add the high and low ‘Density Altitude’ to the daily stats. I will also be adding the ‘Dew Point’ and ‘Air Density’ values.
The Panel is almost finished. I am currently working on database version 1.7.13.027 and this is the output.
Just updated, I am on 1.7.13.44 - when I click “update database” I get “Cannot GET /altertables”
Do I need to do something before doing “update database”?
Send me the data from your About page.
Datebase level: 1.7.13.025
ApplicationVersionServiceUpdate
Alertyes1.7.13.031
AlterTables1.7.13.0251.7.13.026
Archive1.7.13.080yes1.7.13.087
Backfillno1.7.13.007
Citizenyes1.7.13.017
DailyStats1.7.13.021no1.7.13.023
Panel1.7.13.047yes1.7.13.049
Piioyes1.7.13.023
Server1.7.13.06yes1.7.13.09
Start1.7.13.001no
TippingBucketno1.7.13.004
UpdateFiles1.7.13.017no
Utility1.7.13.025no
WeatherCalcno1.7.13.022
WeatherFormulasno1.7.12.017
Maybe screen shot is better?
You need to restart the processes Archive, Panel and Server.
It would be best to run altertables from a terminal window. It seem I put the About page update out before the Server restart.
