What are you expecting to see?
Not to have link when there are not any warnings, it doesnāt exist before. Or to receive some message that warnings are cleared. Anyhow, when you have some button where you can clicking and there are no results or reports first conclusion is that is not working
I understand. All it does is clear the values.
Testersā¦
I have uploaded 1.7.14.test. To get this version, first run updatefiles from a terminal window. If it takes more than 60 seconds, hit CTRL-C and exit the script. Then look for a new folder called config. If it is there you are good. Follow the following instructions. If it is not there, run updatefiles again.
cd config
nano config.json
change database from 1.7.13.test to 1.7.14.test
save the file
run updatefiles
pm2 stop all
node start
Updated, tabs Alert, Panel, PiiO not working. Also in log there are new errors:
āError: ENOENT: no such file or directory, open ā/home/pi/archivesw/panel/panelT.jsonā
at Object.fs.openSync (fs.js:646:18)
at Object.fs.readFileSync (fs.js:551:33)
at resolve (/home/pi/archivesw/archive.js:1024:25)
at new Promise ()
at loadPanelData (/home/pi/archivesw/archive.js:1018:9)
at f1 (/home/pi/archivesw/archive.js:59:17)
at
at process._tickCallback (internal/process/next_tick.js:188:7)ā
Files updated once again, now everything is working.
I am hoping this will be the last of the major structure changes. The changes make the code smaller and easier to maintain.
ATTENTION
For those of you running the test versions, run UpdateFiles and then run Update database.
1.7.14.027 is live
guess I annually need to edit something before running the update ??
2018-11-28 18:14:12 Getting files for update 1.7.13.test
2018-11-28 18:14:12 Starting UpdateFiles v1.7.13.021
2018-11-28 18:14:13 Update Files error
Error: Command failed: bash /home/eric/wfarchive/script/updatefiles.sh /home/eric/wfarchive /log/UpdateFiles.log 1.7.13.test
Is that all that is listed? Usually there is more.
yep, nothing more in the log
Run update again and see what it shows.
@eric Paste this into the terminal window
1.7.13.test
Change to archivesw folder and run again!
remember early installers are still in wfarchive directory
Itās not finding your config.json file
Is the config.json in wfarchive or is it in wfarchve/config?
I have no config directory
it is still in wfarchive
canāt do post 685 to get to that level
Run this in the window
bash -e <(wget -qO - http://fsoft.com/archivesw/1.7.13.027/updatefiles.sh)
had to add ā)ā at the end and result
/dev/fd/63: line 64: /home/eric/wfarchive: Is a directory
Shouldnāt he be at 1.7.14.test?
Just a noob asking!
Everything working, just in Utility.log there are errors:
Utility.log Delete
2018-11-29 00:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 01:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 02:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 02:15:27 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 02:28:25 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 02:28:25 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 03:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 03:00:04 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 04:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 04:00:04 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 05:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 05:00:04 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 06:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 06:00:04 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 07:00:02 MariaDB (2): Error: Connection lost: The server closed the connection. 2018-11-29 07:00:04 MariaDB (2): Error: Connection lost: The server closed the connection.
Thank you. That error is harmless and Iāll be re m.k loving it
