Hey Gary do you have a page of screenshots of your display someplace we can see ?
I don’t but I can easily create one.
Are there any specific screens you want to see?
Hello @GaryFunk
I’m on v1.8.16.030 (for sure I force updated files)
Running Altertables still gives me crashed tables
2019-11-11 18:07:33 Error alterTableIndex (create index): HubStatus timestamp_serial_number
HA_ERR_CRASHED_ON_REPAIR
2019-11-11 18:07:33 Error alterTableIndex (create index): HubStatus serial_number
2019-11-11 18:07:33 Error alterTableIndex (create index): HubStatus datestamp
2019-11-11 18:07:33 Checking table index: PrecipEvent
2019-11-11 18:07:33 Checking table index: RapidWind
2019-11-11 18:07:33 Error alterTableIndex (create index): RapidWind serial_number
2019-11-11 18:07:33 Error alterTableIndex (create index): RapidWind hub_sn
2019-11-11 18:07:33 Error alterTableIndex (create index): RapidWind timestamp
2019-11-11 18:07:33 Error alterTableIndex (create index): RapidWind datestamp
and the devices tab ends dead (can’t load page)
Can you please have a look at a spare moment ? No sure I’m the only one but would appreciate your script to be at your level of exigence (perfect)
Did you run altertables? The field type needs to be changed.
Yes but I just ran it again.
And the log file Shows an error: Error changeTable: DailySky
I have a new repairtable.js ready for download.
USAGE: node repairtable hubevents
replace hubevents with the name of the table that is bad.
Thanks @GaryFunk,
I’ll give it a try soon.
Chuck
I tried using the new repairtable.js but it didn’t seem to fix things. Also ran Altertables and UpdateFiles along with some reboots/restarts of the archive/server for good measure.
I’m having the same issues as @chuckmc and @eric . In general though, the program is working well in that I’m primarily using it to upload to CWOP and PWS.
I tried running the repairtable on most of the items in the altertables.log. I figured things like PrecipEvent, AirBackfill and similar ones didn’t need it and weren’t contributing to the errors.
Are you still seeing errors writing to DailySky?
Yeah, that’s what the AlterTables.log files says.
But in the Archive.log I’m still getting this error:
2019-12-01 21:15:48 Error in insertHubStatus (4): ER_TRUNCATED_WRONG_VALUE_FOR_FIELD: Incorrect integer value: '[479,102]' for column archivesw.HubStatus.mqtt_stats at row 1
Here’s the AlterTables.log entries:
2019-12-01 20:22:20 Starting AlterTables v1.8.16.030
2019-12-01 20:22:23 Dropping table index: DailySky
2019-12-01 20:22:23 Dropping table index: PrecipEvent
2019-12-01 20:22:23 Dropping table index: SkyObservation
2019-12-01 20:22:23 Dropping table index: StrikeEvent
2019-12-01 20:22:23 Checking table index: AirBackfill
2019-12-01 20:22:23 Checking table index: AirObservation
2019-12-01 20:22:23 Checking table index: DailyAir
2019-12-01 20:22:23 Checking table index: DailySensor
2019-12-01 20:22:23 Checking table index: DailySky
2019-12-01 20:22:23 Checking table index: DeviceEvents
2019-12-01 20:22:23 Checking table index: DeviceStatus
2019-12-01 20:22:23 Checking table index: FWUpdate
2019-12-01 20:22:23 Checking table index: HubEvents
2019-12-01 20:22:23 Checking table index: HubStatus
2019-12-01 20:22:23 Checking table index: PrecipEvent
2019-12-01 20:22:23 Checking table index: RapidWind
2019-12-01 20:22:23 Checking table index: SkyBackfill
2019-12-01 20:22:23 Checking table index: SkyObservation
2019-12-01 20:22:23 Checking table index: StrikeEvent
2019-12-01 20:22:23 Checking table index: Xrain
2019-12-01 20:22:23 Checking table index: Z_version
2019-12-01 20:22:23 Error changeTable: DailySky
2019-12-01 20:22:23 ChangeTable: DailySky
2019-12-01 20:22:23 ChangeTable: HubEvents
2019-12-01 20:22:23 ChangeTable: HubStatus
2019-12-01 20:22:24 Process changes complete
2019-12-01 20:22:24 Update Version complete
It’s failing on HubStatus. I’ll look at that nasty see what I find.
Just a shot in the dark…
The HubStatus message changed to add an extra value to the mqtt stats section, so now it’s an array:
Status (hub) [type = hub_status]
"serial_number":"HB-00000001",
"type":"hub_status",
"firmware_revision":"35",
"uptime":1670133,
"rssi":-62,
"timestamp":1495724691,
"reset_flags": "BOR,PIN,POR",
"seq": 48,
"fs": [1, 0, 15675411, 524288],
"radio_stats": [2, 1, 0, 3],
"mqtt_stats": [1, 0]
Right. Altertables was to correct the field but for some reason it did not.
If it helps, here’s a real UDP packet for hub status, as captured by my OpenHAB system. I’m sure you have them too but maybe there’s something weird with mine??
{"serial_number":"HB-00003177","type":"hub_status","firmware_revision":"114","uptime":2903890,"rssi":-33,"timestamp":1575308221,"reset_flags":"BOR,PIN,POR","seq":290085,"fs":[1,0,15675411,524288],"radio_stats":[2,2,26,3],"mqtt_stats":[483,102]}
And one for the sky and air device status. Maybe this has something to do with the Devices tab not displaying correctly?
{"serial_number":"SK-00003301","type":"device_status","hub_sn":"HB-00003177","timestamp":1575308527,"uptime":916744,"voltage":3.33,"firmware_revision":43,"rssi":-30,"hub_rssi":-37,"sensor_status":0,"debug":0}
{"serial_number":"AR-00002283","type":"device_status","hub_sn":"HB-00003177","timestamp":1575308518,"uptime":46663345,"voltage":3.44,"firmware_revision":20,"rssi":-61,"hub_rssi":0,"sensor_status":4,"debug":0}
For those that have the HubStatus error, please get this file and run it.
Gary,
EDIT: not sure why the big font! Can’t seem to change it.
Also, I noticed that the version of altertables is the same: 1.8.16.030 /edit
I tried it and I’m still getting the same errors.
Here’s some snippets from the log files:
2019-12-03 10:35:56 Starting UpdateFiles v1.6.16.030
2019-12-03 10:35:56 Getting files for update 1.8.16.030
2019-12-03 10:35:57 Checking for new Script files
2019-12-03 10:35:57 Checking for new JavaScript files
2019-12-03 10:35:59 Received new file ==>: /altertables.js
2019-12-03 10:36:08 Checking for new Config files
2019-12-03 10:36:11 Checking for new Panel files
2019-12-03 10:36:13 Checking for new Views files
2019-12-03 10:36:28 Checking for new Desktop files
2019-12-03 10:40:31 Starting AlterTables v1.8.16.030
2019-12-03 10:40:32 Dropping table index: DailySky
2019-12-03 10:40:32 Dropping table index: PrecipEvent
2019-12-03 10:40:32 Dropping table index: SkyObservation
2019-12-03 10:40:32 Dropping table index: StrikeEvent
2019-12-03 10:40:32 Checking table index: AirBackfill
2019-12-03 10:40:32 Checking table index: AirObservation
2019-12-03 10:40:32 Checking table index: DailyAir
2019-12-03 10:40:32 Checking table index: DailySensor
2019-12-03 10:40:32 Checking table index: DailySky
2019-12-03 10:40:32 Checking table index: DeviceEvents
2019-12-03 10:40:32 Checking table index: DeviceStatus
2019-12-03 10:40:32 Checking table index: FWUpdate
2019-12-03 10:40:32 Checking table index: HubEvents
2019-12-03 10:40:32 Checking table index: HubStatus
2019-12-03 10:40:32 Checking table index: PrecipEvent
2019-12-03 10:40:32 Checking table index: RapidWind
2019-12-03 10:40:32 Checking table index: SkyBackfill
2019-12-03 10:40:32 Checking table index: SkyObservation
2019-12-03 10:40:33 Checking table index: StrikeEvent
2019-12-03 10:40:33 Checking table index: Xrain
2019-12-03 10:40:33 Checking table index: Z_version
2019-12-03 10:40:33 Error changeTable: DailySky
2019-12-03 10:40:33 ChangeTable: DailySky
2019-12-03 10:40:33 ChangeTable: HubEvents
2019-12-03 10:40:33 ChangeTable: HubStatus
2019-12-03 10:40:33 Process changes complete
2019-12-03 10:40:33 Update Version complete
2019-12-03 10:44:31 Error in insertHubStatus (4): ER_TRUNCATED_WRONG_VALUE_FOR_FIELD: Incorrect integer value: '[496,102]' for column `archivesw`.`HubStatus`.`mqtt_stats` at row 1
Archive.err
TypeError: Cannot read property 'length' of undefined
at Query.<anonymous> (/home/pi/archivesw/archive.js:933:16)
at Query.<anonymous> (/home/pi/archivesw/node_modules/mysql/lib/Connection.js:525:10)
at Query._callback (/home/pi/archivesw/node_modules/mysql/lib/Connection.js:491:16)
at Query.Sequence.end (/home/pi/archivesw/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
at /home/pi/archivesw/node_modules/mysql/lib/protocol/Protocol.js:236:14
at process._tickCallback (internal/process/next_tick.js:61:11)
TypeError: Cannot read property 'end' of undefined
at tcpExit (/home/pi/archivesw/archive.js:1260:12)
at onExit (/home/pi/archivesw/archive.js:1240:2)
at process.<anonymous> (/home/pi/archivesw/archive.js:1224:5)
at process.emit (events.js:203:15)
at process.<anonymous> (/home/pi/archivesw/archive.js:1219:5)
Ah, Crap. The idiot sitting at my computer updated the file but forgot to put it on the server. I’m at a VAMC getting a spinal injection. I’ll be back home in two hours.
Spinal injection?! That sounds fun.
No worries. Sounds like you might have bigger fish to fry. Get to it when you can.
Thanks again!!
The new file is up. You should get version 1.8.16.032
