PiConsole time an hour behind system time
Hello, any thoughts on this time issue? BC entered a new time zone today, not sure if this is related or not. System time shows right, PiConsole shows an hour behind (the difference in minutes and seconds was me.) I also had to rebuild my Pi today, I broke the previous install. This is on Trixie. Cheers!
This is odd. The PiConsole should be using the same time zone information. Can you look at the Timezone in your wfpiconsole.ini file? Does it match America/Vancouver? The key is taken from the Tempest API, so a mismatch between the value returned by the API and your local system setting could cause an offset
Hi Peter, yes wfpiconsole.ini also says America/Vancouver.
Thanks!
His province changed time zone rules. Odds are that the Pi’s Linux TZ rules table set the clock back an hour because it wasn’t updated with the new TZ rules…
The clock is right on the Linux timedatectl command and the desktop. I did just notice that my time is wrong on the Tempest website. I took that screenshot at 13:14.
Screenshot 2026-11-02 at 1.16.14 PM
@eric - Can you please have someone confirm that they have accounted for British Columbia, Canada’s timezone change on the back-end web servers as well as the Hub firmware?
Note to anyone who sees discussions in the news about doing away with daylight savings every spring/fall that there is a heavy technology cost to be paid so that people’s sleep patterns aren’t changed. I’m dealing with a similar issue in my brand new lawn sprinkler controller right now, where the programming app and controller’s schedules are all out of sync since the clocks here went back on Sunday morning…
That would certainly cause the issue.
@allan, please open a terminal on your Pi and run these commands
source ~/wfpiconsole/venv/bin/activate
ptyhon3 -m pip install --upgrade pytz tzlocal
Then try and start the console again with wfpiconsole start. Is the clock difference fixed?
Hi Peter, yes, that fixed the clock difference.
Thanks!
