# Raspberry pi 5 installation fails
**URL:** https://community.tempest.earth/t/raspberry-pi-5-installation-fails/22934
**Category:** WeatherFlow PiConsole
**Created:** [November 14, 2023, 8:05pm UTC](https://community.tempest.earth/t/raspberry-pi-5-installation-fails/22934 "2023-11-14T20:05:14Z")
**Posts on this page:** 1
**Showing post:** 2
<div class="post-metadata">
### Author: ![vinceskahan](https://sea2.discourse-cdn.com/flex020/user_avatar/community.tempest.earth/vinceskahan/32/2785_2.png) [@vinceskahan](https://community.tempest.earth/u/vinceskahan)
#### Post date: [November 14, 2023, 8:39pm UTC](https://community.tempest.earth/t/raspberry-pi-5-installation-fails/22934/2 "2023-11-14T20:39:24Z")
</div>
> [@Raspberry Pi 5 and Operating Systems](https://community.tempest.earth/t/raspberry-pi-5-and-operating-systems/22623):
> Update: 26th October 2023 The Raspberry Pi Foundation recently announced the release of the Raspberry Pi 5 and the new Raspberry Pi OS based on Debian Bookworm. Please note the following compatibility limitations: The PiConsole is compatible with Raspberry Pi OS based on Debian Bookworm or Debian Bullseye. Either OS can be used on a Pi3 or a Pi 4. Updates to the PiConsole are no longer compatible with Raspberry Pi OS (Buster). If you are running this OS on a Raspberry Pi 3, please update to B…
Note - no support for pi5 at this time
> [@WeatherFlow PiConsole Support Unavailable](https://community.tempest.earth/t/weatherflow-piconsole-support-unavailable/22882):
> Hi all, just a heads up that I will be working in Antarctica snowflake until late January 2024 and therefore I will not be available to provide support for the PiConsole until I return. Apologies in advance for any issues that may crop up during my absence. Hopefully they are minor!
Note - no official support available for a number of months
That said, run “dpkg --print-architecture” to show if it shows ‘arm64’. The kernels they use show aarch64 even on 32bit os. The 32bit will report ‘armhf’ on a pi4. If you’re really running 64bit, try 32bit. You can’t break anything. It already doesn’t work.
_[View the full topic](https://community.tempest.earth/t/raspberry-pi-5-installation-fails/22934)._
