A new version of the WeatherFlow PiConsole is now available: v26.4.1
Added solar/astronomical support for all latitudes
Fixed bug when METAR cloud information is missing
To update please run wfpiconsole stop followed by wfpiconsole update . Please make sure any local changes to the code or custom panels are backed up.
This release contains a complete rewrite of the sunrise/sunset and moonrise/moonset code to make it functional at all latitudes (particularly high northern latitudes were the sun may not rise/set some days, or sunset happens before sunrise on the same day). For the vast majority of users, no visible changes should be seen. If you run into any issues, please get in touch.
A new version of the WeatherFlow PiConsole is now available: v26.4.2
Added option to switch between NearCast and raw rain accumulation values
To update please run wfpiconsole stop followed by wfpiconsole update. Please make sure any local changes to the code or custom panels are backed up.
This release contains the option to switch between NearCast and raw rain accumulation values. The option can be found under Menu ā Settings ā System The default setting will show raw accumulation values. For stations in locations where NearCast is not available, switching to the NearCast display will make all rain accumulation values show as -
If you like the PiConsole, please consider supporting its development
