The WeatherFlow PiConsole is a Python console that displays the data collected by a WeatherFlow Tempest or Smart Home Weather Station. The console uses either the WeatherFlow REST API and websocket service or the local UDP connection to stream data from your station in real time, including the 3-second rapid wind updates. In UDP only mode, the console requires no connection to the internet once installation is complete.
The console is fully supported for Raspberry Pi 3 Model B/B+, Raspberry Pi 4 and Raspberry Pi 5 running the 64 bit version of Raspberry Pi OS Trixie or the 32/64 bit version of Raspberry Pi OS Bookworm. It can be run on earlier models, but no direct support is provided for these systems. It is not compatible with Raspberry Pi Zero or Zero W. For full compatibility details, see below.
Code and Instructions: The code and instructions about how to get the PiConsole up and running can be found on GitHub
Latest Version: v26.4.2 (29th April 2026; see announcements and updates)
- Wind speed and direction including three second rapid wind updates
- Outdoor air temperature/humidity/feels Like
- Indoor air temperature (requires an indoor Air module)
- Daily maximum and minimum outdoor/indoor temperature
- Daily maximum wind gust and daily averaged wind speed
- Atmospheric pressure, pressure trend, and expected conditions
- Daily maximum and minimum pressure
- Current rainfall rate along with today/yesterday/monthly/yearly totals
- Time and distance to latest lightning strike
- Lightning strike frequency
- Last 3 hours/today/monthly/yearly lightning strike totals
- Solar radiation and UV index
- Sunrise/sunset information
- Moonrise/moonset information
- Location specific forecast from WeatherFlow
- Location specific Sager Weathercaster Forecast
- Settings screen to change display units and other options
The console layout is fully customisable, allowing you to personalise how you display the data from your WeatherFlow station.
Screenshot
Compatibility - Raspberry Pi
The console is fully supported for Raspberry Pi 3 Model B/B+, Raspberry Pi 4 and Raspberry Pi 5 running the 64 bit version of Raspberry Pi OS Trixie or the 32/64 bit legacy version of Raspberry Pi OS Bookworm. It can be run on earlier models, but no direct support is provided for these systems. It is not compatible with the 32 bit version of Raspberry Pi OS Trixie or Raspberry Pi Zero or Zero W. While the console is compatible with Raspberry Pi 3, the graphics hardware on this model is ageing and performance of the console can be sluggish. It is recommended to use a Pi 4 or above. The console is not compatible with Raspberry Pi OS Buster.
The console is compatible with the Raspberry Pi Official 7 inch Touchscreen or other HDMI equivalents. Note, screens that attach solely to the GPIO pins (SPI) are not compatible and the console will not start.
Compatibility - PC / Laptop
The console is fully supported on laptops and PCs running Ubuntu 22.04 LTS or later, or the desktop version of Raspberry Pi OS. It will run on other Debian-based operating systems with Python version 3.9 or above, but no direct support is provided for these environments.
Credits
Credit and thanks to @Weather34 and his Home Weather Station template .
