API not working
playing around using web examples I keep getting not found
Somehow I got kicked out so here it is again . I created and access token and using that and my station ID returns not found. I assume the station ID is the number in the URL when you access your station. In the examples do you leave in the open and closing brackets for the item. Is there possibly a delay in authorizing th key?
For people to be able to help you out, maybe explain a bit what you are doing. For now it is a guessing game.
