Piece of Pi.
Might test it in the hope not to blow the whole stuff
gotta remember the db logins lol
Or add a user with limited (read only) access
Might solve both issues.
true but need root access to mysql to add the user, hence why I need to find those logins again
Grafana is beyond the scope of ArchiveSW, however I will add support to the built in web server and create pages where needed.
Someone with Grafana experience will need to tell me what is needed.
If you didnāt change the default setup, the login is root and no password needed. It only requires that you do so from the RPI as itās limited to a local login only.
already get past bloody upgrade of the system ⦠the more they go the less it is easy ⦠canāt they keep it simple as it was ⦠
installing grafana was very quick via apt-get (in my case ubuntu server)
and as mentioned by Gary, just link to the database after making a new user with select priviledge
Example:
CREATE USER āgrafanaReaderā IDENTIFIED BY āpasswordā;
GRANT SELECT ON mydatabase.mytable TO āgrafanaReaderā;
now learn grafana and see what I can get out of all that data
I can create an install script that will make it super simple. And I can add it to the ArchiveSW install script to add a grafana user to MariaDB.
basically it is
install grafana (dependecies etc) described here
add a user that only has select option as to avoid it messing the data
user has to log in grafana and link database and from there on it is play and learn
Links to graphs can be added to the Display to allow for interactive viewing. And a page on the Server can be created to display the graphs created.
Am not yet there
but would be nice
What is the best / safest way to shut down for a reboot?
Stop all processes. Stop Archive first and Server last.
Is there a particular process you want to do? I could easily add a command to shutdown ArchiceSW with an option to reboot the RPi.
I could add this to the Process page in about 5 minutes.
I had a power glitch for a couple seconds and now the high/lows arenāt updating. Thought Iād do a reboot and see if that fixed it and just wanted to make sure I was doing it correctly. A reboot link in the Server Panel would be handy.
What I do notice is a lot of offline/online entries in the Alert log for both the Air and Sky. I have the hub located within 30ā of them so not sure what that is about or if that is somewhat normal.
During the glitch did the RPi lose power? It could be a database error if a table became damaged.
Shutdown the processes and reboot. Then check the logs.
Yes, lost power. I really need to suck it up and get a backup PS for it. With the rainy season just around the corner itās not uncommon to have power āblinksā during thunderstorms.
After the reboot the highs/lows arenāt updating, they pull a number from what appears to be about an hour ago. I also see the counters next to the batteries are not incrementing.
The errors I see in the logs after a reboot are
panel.err
(node:1075) [DEP0112] DeprecationWarning: Socket.prototype._handle is deprecated
archive.err
(node:1146) [DEP0112] DeprecationWarning: Socket.prototype._handle is deprecated
alert.log
2019-05-27 09:33:05 Caught interrupt signal: 3
2019-05-27 09:33:05 onExit: 3
2019-05-27 09:33:05 Closed timers
2019-05-27 09:33:05 Closed TCP
2019-05-27 09:33:05 TCP client has disconnected with code: 3
2019-05-27 09:17:30 Starting Alert v1.7.14.037
2019-05-27 09:17:30 TCP client active on: 127.0.0.1:54386 to 127.0.0.1:9090
2019-05-27 09:34:42 ==> RPi Rebooted
2019-05-27 09:34:42 ==> piReboot
2019-05-27 09:42:31 ==> Offline AR-00007198
2019-05-27 09:42:31 ==> deviceOffline
2019-05-27 09:45:31 ==> Offline SK-00004877
2019-05-27 09:45:31 ==> deviceOffline
2019-05-27 09:45:31 ==> Offline AR-00009177
2019-05-27 09:45:32 ==> Online SK-00004877
2019-05-27 09:45:32 ==> deviceOnline
2019-05-27 09:45:33 ==> Online AR-00009177
2019-05-27 09:45:33 ==> deviceOnline
2019-05-27 09:46:08 ==> Online AR-00007198
2019-05-27 09:46:08 ==> deviceOnline
archive.log
2019-05-27 09:34:31 Starting Archive v1.8.16.111
2019-05-27 09:34:32 TCP client active on: 127.0.0.1:54396 to 127.0.0.1:9090
2019-05-27 09:34:41 appRestart : :
2019-05-27 09:34:42 piReboot : :
2019-05-27 09:42:31 deviceOffline : AR-00007198 :
2019-05-27 09:45:31 deviceOffline : SK-00004877 :
2019-05-27 09:45:31 deviceOffline : AR-00009177 :
2019-05-27 09:45:32 deviceOnline : SK-00004877 :
2019-05-27 09:45:33 deviceOnline : AR-00009177 :
2019-05-27 09:46:08 deviceOnline : AR-00007198 :
server.log
2019-05-27 09:17:28 Starting Server v1.8.16.042
2019-05-27 09:17:28 Listening to HTTP on: localhost:8080
2019-05-27 09:17:28 Listening to TCP on: localhost:9090
2019-05-27 09:17:30 TCP server connection: 54386
2019-05-27 09:17:33 TCP server connection: 54390
2019-05-27 09:34:32 TCP server connection: 54396
2019-05-27 09:34:41 Wrote event.json
2019-05-27 09:34:42 Wrote event.json
2019-05-27 09:42:31 Wrote event.json
2019-05-27 09:45:31 Wrote event.json
2019-05-27 09:45:32 Wrote event.json
2019-05-27 09:45:33 Wrote event.json
2019-05-27 09:46:08 Wrote event.json
2019-05-27 09:54:31 Wrote event.json
(note: I do see the following once in awhile 2019-05-27 06:43:55 Error running sudo systemctl restart hostapd)
start.log
2019-05-27 09:17:07 Starting Start v1.8.16.006
2019-05-27 09:17:23 Starting ArchivSW Server
2019-05-27 09:17:28 Starting ArchivSW Alert
2019-05-27 09:17:31 Starting ArchivSW Panel
2019-05-27 09:34:25 Starting ArchivSW Piio
2019-05-27 09:34:29 Starting ArchivSW Archive
Everything looks good. Iāll add a shutdown and push out new files tonight
Oh yes. Thatās was a fix I added for my station and I need to finish it. Thanks for the report.
Why arenāt the highs/lows updating?
Ah, I see what you mean.
Delete all the log files, restart Archive and see what shows up in the log files.
