Something may be interrupting the internal communications between the processes.
What device do you use for aq?
I always wonder what they really measure … VOC is so general .
the sensors full tech specs
Are you thinking of adding this to ArchiveSW?
Yes. I will be creating a table to capture the data and I will be adding it to the display as soon as I figure out how to display the data.
Nice, I ordered 2 just now. (1 for ArchiveSW and 1 to play with)
Let me know if you need a tester.
Well, now, I guess I better get the table designed and import code written. This is a pretty simple change but will require some configuration.
If you have any ideas on how to display the data let me know.
only problem in my case, the device running your script is in the cellar … I think you can only capture via USB the data so measuring what happens down there is not really going to give me much.
unfortunately eric as you discovered this doesnt measure particle matters , whilst a useful tool for detecting gases we have two gas sensor using that chip which is just a white plastic box with two led and a buzzer . gary you might want to look for a solution measuring particle matters as well as VOC . there is a lot interest in measuring pm2.5/10 and VOC amongst other concerns . ive seen a few rasperry and other small projects offering a wider range of detecting concerns .
one project caught my eye some months ago https://www.instructables.com/id/See-the-Air-Your-Community-Breathes/
anyway i think its an interesting addition to owning a weather station and certainly has become a popular interest over the last year or so. good luck…brian
There are ways to solve that. Use a long USB cable or use additional boards to relay the data. The possibilities are vast and readily available.
I added this device at the request of a user. If you have a device you want, I’ll be happy to add it. You can even build your own device and I’ll add support for it.
exactly what i use think @dsj had one but he lost it somewhere in china. highly recommend one of these if your the conscientious type of having things look tidy and modern…
It seems a nice device BUT it seems to be 100% cloud based so that is NOT an option.
I agree totally, I was just providing the FYI as to where things seem to be trending.
I’m not committed to using the uThing::VOC sensor in ArchiveSW. I can use it in other projects. If there is a better one, I’ll get it. I do have some interest in measuring pm2.5/10 so if there are suggestions, I’ll look into them.
Most of the projects I seen for pm2.5/10 use the SDS011 sensor but couldn’t find any offered in the US. You can find them on Aliexpress for under $20 shipped that include the USB interface. A couple I seen are
and
Principal an interesting device,
but cloud based and, for my opinion, to expensive for the features.
How dot they get the outdoor values ?
I like your ideas so keep me informed on things you like.
