Dew point higher than my temperature
A simple fix would be to email weatherflow support team about your RH issue. I had an issue one time where my humidity capped out around 92-93% and wouldn’t go any higher, emailed the support team and they were able to adjust the calibration to fix that. Their support team is great, I would recommend using it. They will take a few days to respond because they’re pretty busy right now but they will get back with you and give you some options. My Tempest tracks very closely to the local NWS station on temp, humidity and dewpoint.
Thank you vtyler98. I did as you said but I didn’t find any email options so I sent a request via “open ticket”.
bw
