Hello,
looking out for a good spot to install the Tempest, I am wondering if the device needs easy physical access. As it is solar powered, there is no need to replace batteries. As there are no moving parts, no need for maintenance and if installed in a “clean” spot, there should not be the need for much cleaning as well.
But what about the system stability? Is it likely that it loses connection and needs some buttons pressed or is it designed for really being remote. Like a mars rover
Thanks
