Hub LED/USB port location
That is correct.
The LED is bright enough that I can see it even when the Hub is facing forward.
That’s funny I have an envoy as well, but it is the hub that collects the data from my solar panels with enphase micro inverters. So two different companies called their hub envoy.
That’s what I was trying to avoid. But no big deal, just turned the hub around 180
LED in front facing into room/usb port facing wall
Yet most of us want our computer ethernet port lights on the ‘back’ of the unit.
Unless you rack mount, in which case LEDs facing forward is a must-have.
That green LED is so blindingly bright that you know it’s green no matter which side it’s on…even with a LightDims dimmer overlay on it.
Black electoral tape V.1.2 will work too
