I have a bit of feedback. And 2 questions. 1 how does the station detect lightning and 2 is it able to determine between positive and negative bolts? Also would it be okay if yall make is so you can drag along the data inside the graph instead of only tapping on it? Also if it can tell the difference between bolts, I think it would be awesome to add a color scheme to each bolt type. Red being positive and blue being negative
There are a few topics on lightning detection that answer your first question.
Your second question is no.
As for your suggestion, you can drag the data left and right.
I was referring to lightning data but I do see your point. Thank you for the reply! And darn, that would be awesome if it could. Would have made some pretty cook graphics haha. I appreciate the reply!
