Need some API / php help
First post (I am probably using the wrong terms, be gentle),
I have tried some searches, but not knowing what terms to use, I am coming up empty.
I am trying to use the API to pull data into a MariaDB. I have done this with a different weather station manufactures API, so I know it works.
When I try to read the string and assign it to variables, I don’t get the expected results. It must be how I have things in my foreach loop formatted. (here is a snippet of the code in question:)
$apiString = 'https://swd.weatherflow.com/swd/rest/observations/station/[sanitized_station_id]?token=[sanitized_token]';
$json = file_get_contents($apiString);
//convert json object to php associative array
$data = json_decode($json, true);
// Loop through the array
foreach ($data as $row)
    $station_id = $row['station_id'];
 $sql = "INSERT INTO $tableName
    `Station_Name`
  VALUES
      '$station_id'
  echo "$sql<br />";
(The echo statement gives me the following output:)
INSERT INTO TempestWeatherData ( Station_Name ) VALUES ( ‘’ )
INSERT INTO TempestWeatherData ( Station_Name ) VALUES ( ‘L’ )
INSERT INTO TempestWeatherData ( Station_Name ) VALUES ( ‘A’ )
I should only have one “Insert Into” statement (not 12) and the “Value” should have the ‘station_id’ rather that an empty value.
Can anybody point me in the right direction to get my “foreach” section formatted correctly?
Maybe some code examples.
Thanks!
Scott
Add an echo of $data above your foreach loop, and an echo of $row within your loop so we can see what the data looks like.
I will have to get that info worked up in a bit, but, I did get it to only display one line (instead of 12).
BUT, I am only getting one value (the first on, station_name) back.
I feel it has something to do with my formatting.
i.e.
$air_temperature = $data['air_temperature'];
Like I need more brackets or curly braces.
Thanks,
Scott
I may have found my solution.
I need to do some more testing, but this got me going in the right direction:
$air_temperature = $data['obs']['0']['air_temperature'];
Thanks,
Scott
well of course, you need to follow the API’s data structure…
Yeah…
I had that set up correctly (this morning :confused: )and took it out to test something and neglected to put it back.
It’s the simple things…
Thanks,
Scott
