I am working on a script to send weather data to a Magic Mirror and will be doing so from a Raspberry Pi. I will take the data from the WFArchiver, convert it to my local values and send only the data necessary for the Magic Mirror. I want to show how esay it is to do this from the Pi.
The code is listed in the next post.
As you can see, I had to write more code to get the proper Broadcast address than to send the UDP packet.
const dgram = require('dgram');
const network = require('network');
const server = dgram.createSocket("udp4");
const PORT = 6024;
var broadcastIP;
network.get_active_interface(function(err, obj) {
console.log(obj);
console.log('');
broadcastIP = IPv4_Address(obj.ip_address, obj.netmask);
console.log('Broadcast IP = ' + broadcastIP);
server.bind(function() {
server.setBroadcast(true);
setInterval(broadcastNew, 3000);
function broadcastNew() {
var message = new Buffer("Broadcast message!");
server.send(message, 0, message.length, PORT, broadcastIP, function() {
console.log("Sent '" + message + "'");
function IPv4_Address( addressDotQuad, netmaskDotQuad ) {
var addressInteger = IPv4_dotquad_to_int( addressDotQuad.toString() );
var addressBinStr = IPv4_int_to_binstr( addressInteger );
var netmaskInteger = IPv4_dotquad_to_int( netmaskDotQuad.toString() );
var netmaskBinStr = IPv4_int_to_binstr( netmaskInteger );
var netbcastBinStr = IPv4_calc_netbcastBinStr( addressBinStr, netmaskBinStr );
var netbcastInteger = IPv4_binstr_to_int( netbcastBinStr );
return IPv4_int_to_dotquad( netbcastInteger );
/* dotted-quad IP to integer */
function IPv4_dotquad_to_int( strbits ) {
var split = strbits.split( '.', 4 );
var myInt = (
parseFloat( split[0] * 16777216 ) /* 2^24 */
+ parseFloat( split[1] * 65536 ) /* 2^16 */
+ parseFloat( split[2] * 256 ) /* 2^8 */
+ parseFloat( split[3] )
return myInt;
/* integer IP to binary string representation */
function IPv4_int_to_binstr( strnum ) {
var numStr = strnum.toString( 2 ); /* Initialize return value as string */
var numZeros = 32 - numStr.length; /* Calculate no. of zeros */
if (numZeros > 0) {
for (var i = 1; i <= numZeros; i++) {
numStr = "0" + numStr
return numStr;
/* logical OR between address & NOT netmask */
function IPv4_calc_netbcastBinStr( addressBinStr, netmaskBinStr ) {
var netbcastBinStr = '';
var aBit = 0; var nmBit = 0;
for( pos = 0; pos < 32; pos ++ ) {
aBit = parseInt( addressBinStr.substr( pos, 1 ));
nmBit = parseInt( netmaskBinStr.substr( pos, 1 ));
if( nmBit ) {
nmBit = 0; /* flip netmask bits */
} else {
nmBit = 1;
if( aBit || nmBit ) {
netbcastBinStr += '1';
} else {
netbcastBinStr += '0';
return netbcastBinStr;
/* binary string IP to integer representation */
function IPv4_binstr_to_int( binstr ) {
return parseInt( binstr, 2 );
/* integer IP to dotted-quad */
function IPv4_int_to_dotquad( strnum ) {
var byte1 = ( strnum >>> 24 );
var byte2 = ( strnum >>> 16 ) & 255;
var byte3 = ( strnum >>> 8 ) & 255;
var byte4 = strnum & 255;
return ( byte1 + '.' + byte2 + '.' + byte3 + '.' + byte4 );
