mrburns
1
Can anyone advise what the typical output voltage at the wafer when on mains voltage is please.
No batteries installed.
Mine was 3.86v but the tempest will not charge.
When I put 8 energizer batteries in it charges so I am suspect of mains power.
Cheers all
If you have a DC benchtop power supply, you can always try to manually charge the Tempest. Just stay below 5V and get the polarity correct.
I’ll try to remember to test the output when I get home from work.
gizmoev
3
I measured 3.93V when using the supplied AC adapter and 3.58V when on Energizer Lithium Ultimate batteries.
thanks for the update; appreciated.
system
Closed
5
