Purple Air AQI Display How To
How to display Purple Air AQI:
With help from Peter and vinceskahan, I implemented a AQI display panel using a Purple Air sensor. Attached are the files I use. The AQI is labeled Example in the .ini file. Remove the .txt extension from the two files before use. Change the URL to that of your Purple Air sensor.
customPanels.py.txt (1.1 KB)
customPanels.kv.txt (604 Bytes)
[PrimaryPanels]
PanelOne = Temperature
PanelTwo = WindSpeed
PanelThree = Barometer
PanelFour = Rainfall
PanelFive = SunriseSunset
PanelSix = Example
