RSSI on battery cards?
Is it possible to add the sensor’s RSSI to each device’s battery card, as the true RSSI and/or a faux signal strength bar gauge?
There have been cases here where people have encountered signal strength problems, and interpreting the hidden RSSI value is not exactly consumer-friendly…
That is an excellent idea!
Jim
Yes, converting the RSSI values to consumer-friendly signal-strength iconography like you see in many other apps has been on our roadmap for a long time… same with battery level… and they are both still on our roadmap :slight_smile:
