Hello. Just noticed elevation in app settings but it reads 0.0 and I can’t seem to be able to change it. Does anyone know how to set that value? I assume it should read what my actual elevation is?
I assume you are referring to this setting …
I believe that is computed based on the “Height above ground” that you have set for the sensor device. Select “Manage Devices” and then select your Tempest at your location (it is ID’d by a string that starts with “ST-” . The Elevation is computed from that setting, plus ground level height above sea level, as I understand things.
