Would be nice to see on the Rain history graphs an “Actual” and “Raincheck” line value. This way when checking the history we can easily compare the two values of what the SKY actually measured for rain and what Rain Check adjusted it to. The only way to compare the two daily is to keep toggling the Rain Check setting off and on.
If you are uploading your station to WU or other sites you can check and compare the 2 because WU does not accept a adjusted value , but I agree with you about being able to see both values
I don’t know if the graph is where to show it or not, but I would definitely love to see the actual vs rain check somewhere to see how accurate the station is compared to the rain check data. That would also allow us to make a better decision as to whether we need to use the rain check or not.
