Hi @edg, welcome to the community.
There are a couple of different options that might suit your needs. Firstly, in the WF Tempest app there is a history tab. This gives the high/low temperature and accumulated rain for each 24 hour period, but admittedly it is not between 7 am and 7 am.
Secondly, there is a rich collection of third party applications, some of which will almost certainly suit your needs. Ones that immediately come to mind are WeeWX UDP driver for WeatherFlow station, ArchiveSW - Display & Data Archive Storage, and WeatherFlow UDP listener and MQTT/InfluxDB publisher utility.
Finally, you can always use the open API provided by WF to roll your own solution (https://weatherflow.github.io/SmartWeather/api/). If you are familiar with Python or another programming language you could readily write a script to download all the data from the past 24 hours, calculate the max/min and total accumulation, and run it just after 7 am each day.
Hope this helps!
