My application of wfpiconsole is a portable one and I need to make adjustments in Station Elevation frequently. When I change it in the app so that SLP matches the Altimeter setting of an airport I am on I have to adjust it in wfpiconsole.ini to the same value so the readings match. Is there a way to read and use the Station Elevation from the WeatherFlow servers that’s updated by the app instead of using the value in the Elevation setting in wfpiconsole.ini?
By the way this a fantastic piece of work Peter. I’m still slowly try to figure out a few things to tweak it to my needs.
