Tempest battery only discharging even on sunny days
Ive had my Tempest for years but only now am seeing this problem. Regardless of sunny days the battery will no longer charge. It notices increases in UV radiation so I assume solar charging is possible.
Does this mean my battery has lost ability to charge? How do I replace it?
Thanks for any insight.
Call or write to customer service and have them do a remote diagnostic check. They’ll be able to assess the battery and offer a solution(s)
This is also my problem … it’s dropped to Eco mode, even though it’s been really sunny for the last few weeks.
I suggest opening a support ticket ASAP with the link at the top of every forum page, before the battery goes dead and they can’t troubleshoot it…
I did write to them and they responded quickly. They concluded it is a hardware issue: either battery failing to charge or solar panels failing to provide power (eg. failing or dust covering them).
They offered me to upgrade to the latest at 50% off. I opted for this. I’ve had this unit for nearly 4 years so it is probably about time anyhow.
