Hello Dividedsky
Indeed switching to the Tempest implies a little adaption to what you’re used to
Voltage levels are way lower as it uses another type of batteries (LTO). +/- 2.80V is fully charged (when it is in the sun) and it’ll drop pretty quickly to +/- 2.65 V once the sun goes away (this is normal so don’t go bonks when you see this, 2.8 is max charge voltage and it’s nominal stable max voltage without charging i around 2.65)
Also you have power saving modes but you can read it in this help section in all details
