Theoretical UV calculation tool
301… That would be quite the scorcher :slight_smile:
Showing just over 9 still for you…
Interesting… I just retried with two different browsers and I’m still getting 1.07.
This is what I just got.
Oh boy… Got Undefined offset twice just now. Manually typed in the numbers just to make sure.
Hm… don’t break your back too much on this although it is an interesting thing.
Everybody try again… had some timezone offset issues…
–Sam
Long list of error messages again :*(
Kill that browser and reopen…
Hm. I get 1.1 from a fresh browser. Hm.
What browser are you using? Your selected time is not coming across.
Is there a chance that the time is not setting for my zone?
Ipad safari and chrome. Both show 1.* value
Will check on my wife’s ipad, and my Macbook…
But yeah, it’s a time issue.
In work!!!
Try the HTTPS version:
https://beentheresailedthat.com/ws/server/uv.html
Same thing again. 1.* range. Tried with iPad, iMac, and even a ChromeBook. Same results.
Something about the time change maybe …
I’m seeing different results with Safari on my Dev iPhone… will look into the iOS/macOS issue. I’m sure its’ a javascript problem.
Until then, you can use the PHP endpoint:
http://beentheresailedthat.com/ws/server/php/getUvByCoordWeb.php?lat=XXXX&lon=XXXX&date=XXXX
Just use a EPOCH in seconds for the date… time since midnight:
Wow… I’m breaking it more. Lots of errors again with the PHP endpoint just as I try to open it.
