Hello. First, I’m a novice so please bear with me.
I had some wifi issues so had to semi start over after many months of running. I’m running from a raspberry pi 4.
now, it’s saying unable to fetch station metadata.
I understand it has a conflict on the personal use token and api.
i was able to revoke or reset both.
But I’m not sure where to put those long numbers cut/paste?
You need to update the values in wfpiconsole.ini. You can either edit the file directly, or you can delete it entirely and when you start the console again it will take you through the processes of generating a brand new .ini file
