I have a Versa Fitbit 2 watch and you can download custom faces for it. One I like is made by KATANA https://gallery.fitbit.com/search?terms=katana
It says I can apply for an API for the weather data for it, I would like to have my SMART WEATHER data on it instead, is this possible?
----This is a clockface gives the weather, location and some activity stats in a user-friendly format. You will need to get a OpenWeather API key which can be pasted into the Settings page. They do not charge for this. Instructions are at https://openweathermap.org/appid.
directly no, but if you set up a local pi or equivalent with weewx, use the driver to get UDP data from WF and then up it to openweathermap
other option is to use meteobridge
and another option is weather display
And for sure I forgot some but you already have 3 options
