Hi Peter,
[INFO ] [Base ] Leaving application in progress...
File "kivy/properties.pyx", line 861, in kivy.properties.ObservableDict.__getattr__
KeyError: 'PanelSix'
During handling of the above exception, another exception occurred:
File "/home/pi/.local/lib/python3.7/site-packages/kivy/lang/builder.py", line 242, in create_handler
return eval(value, idmap), bound_list
File "/home/pi/wfpiconsole/wfpiconsole.kv", line 1091, in <module>
pos_hint: {'x': app.CurrentConditions.ids.PanelSix.x/app.window.width, 'y': 2/app.window.height}
File "kivy/properties.pyx", line 864, in kivy.properties.ObservableDict.__getattr__
AttributeError: 'super' object has no attribute '__getattr__'
File "/home/pi/.local/lib/python3.7/site-packages/kivy/lang/builder.py", line 697, in _apply_rule
rctx['ids'])
File "/home/pi/.local/lib/python3.7/site-packages/kivy/lang/builder.py", line 247, in create_handler
cause=tb)
kivy.lang.builder.BuilderException: Parser: File "/home/pi/wfpiconsole/wfpiconsole.kv", line 1091:
1089:<updateNotification>:
1090: size_hint: (None, 76/480)
>> 1091: pos_hint: {'x': app.CurrentConditions.ids.PanelSix.x/app.window.width, 'y': 2/app.window.height}
1092: width: app.CurrentConditions.ids.PanelSix.size[0]
1093: UpdateNotifBackground:
File "main.py", line 521, in <module>
wfpiconsole().run()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/app.py", line 950, in run
runTouchApp()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/base.py", line 582, in runTouchApp
EventLoop.mainloop()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/base.py", line 347, in mainloop
self.idle()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/base.py", line 387, in idle
Clock.tick()
File "/home/pi/.local/lib/python3.7/site-packages/kivy/clock.py", line 733, in tick
self.post_idle(ts, self.idle())
File "/home/pi/.local/lib/python3.7/site-packages/kivy/clock.py", line 776, in post_idle
self._process_events()
File "kivy/_clock.pyx", line 616, in kivy._clock.CyClockBase._process_events
File "kivy/_clock.pyx", line 649, in kivy._clock.CyClockBase._process_events
File "kivy/_clock.pyx", line 645, in kivy._clock.CyClockBase._process_events
File "kivy/_clock.pyx", line 218, in kivy._clock.ClockEvent.tick
File "/home/pi/wfpiconsole/lib/system.py", line 111, in check_version
updateNotification(latest_ver).open()
File "/home/pi/wfpiconsole/panels/update.py", line 31, in __init__
super().__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/modalview.py", line 187, in __init__
super(ModalView, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/anchorlayout.py", line 68, in __init__
super(AnchorLayout, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/layout.py", line 76, in __init__
super(Layout, self).__init__(**kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/widget.py", line 361, in __init__
rule_children=rule_children)
File "/home/pi/.local/lib/python3.7/site-packages/kivy/uix/widget.py", line 465, in apply_class_lang_rules
File "/home/pi/.local/lib/python3.7/site-packages/kivy/lang/builder.py", line 543, in apply
File "/home/pi/.local/lib/python3.7/site-packages/kivy/lang/builder.py", line 712, in _apply_rule
e), cause=tb)
rctx['ids'])
cause=tb)
And:
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
On a PI 3.
