Seems not to be working here:
root@raspberrypi:~# curl -sSL https://peted-davis.github.io/wfpiconsole | bash
[â] Root user check passed
[â] Hardware check passed (armv7l)
[â] OS check passed (Raspbian GNU/Linux 10 (buster))
Installing WeatherFlow PiConsole
[â] Checking for updated packages
[i] No updated packages found
[i] WeatherFlow PiConsole dependency checksâŚ
[â] Checking for git
[â] Checking for curl
[â] Checking for rng-tools
[â] Checking for build-essential
[â] Checking for python3-dev
[â] Checking for python3-pip
[â] Checking for python3-setuptools
[â] Checking for libssl-dev
[â] Checking for libffi-dev
[â] Checking for libatlas-base-dev
[â] Checking for jq
[i] Installing WeatherFlow PiConsole Python modulesâŚ
[â] Updating Python package manager
[â] Installing Python module cython
[â] Installing Python module websockets
[â] Installing Python module numpy
[â] Installing Python module pytz
[â] Installing Python module ephem
[â] Installing Python module packaging
[â] Installing Python module pyOpenSSL
[i] Kivy Python library dependency checksâŚ
[â] Checking for pkg-config
[â] Checking for libgl1-mesa-dev
[â] Checking for libgles2-mesa-dev
[â] Checking for libgstreamer1.0-dev
[â] Checking for gstreamer1.0-plugins-bad
[â] Checking for gstreamer1.0-plugins-base
[â] Checking for gstreamer1.0-plugins-good
[â] Checking for gstreamer1.0-plugins-ugly
[â] Checking for gstreamer1.0-omx
[â] Checking for gstreamer1.0-alsa
[â] Checking for libmtdev-dev
[â] Checking for xclip
[â] Checking for xsel
[â] Checking for libjpeg-dev
[â] Checking for libsdl2-dev
[â] Checking for libsdl2-image-dev
[â] Checking for libsdl2-mixer-dev
[â] Checking for libsdl2-ttf-dev
[i] Kivy Python library installation check (will be installed)
[â] Installing Kivy Python library
[i] Updating Kivy configuration for touch screenâŚGebruik: usermod [opties] L OGIN
Opties:
-c, --comment COMMENTAAR nieuwe inhoud van het GECOS-veld
-d, --home THUIS_MAP nieuwe thuismap voor het gebruikersaccount
-e, --expiredate VERVAL_DATUM stel account-vervaldag in op VERVAL_DATUM
-f, --inactive INACTIEF stel na het verlopen van het wachtwoord de
niet-actieve periode ervan in op INACTIEF
-g, --gid GROEP forceer het gebruik van GROEP als nieuwe primair e
groep
-G, --groups GROEPEN nieuwe lijst van bijkomende GROEPEN
-a, --append voeg de gebruiker toe aan de bijkomende GROEPEN,
vermeld bij de optie -G, zonder hem/haar
te verwijderen uit andere groepen
-h, --help toon deze hulptekst en sluit af
-l, --login NIEUWE_NAAM nieuwe waarde voor de gebruikersnaam
-L, --lock vergrendel het gebruikersaccount
-m, --move-home verplaats de inhoud van de thuismap naar de
nieuwe locatie (enkel gebruiken met -d)
-o, --non-unique gebruik van een identiek (niet-uniek) UID toesta an
-p, --password WACHTWOORD gebruik versleuteld wachtwoord als nieuw wachtwo ord
-R, --root CHROOT_MAP basismap voor chroot
-s, --shell SHELL nieuwe aanmeld-shell voor het gebruikersaccount
-u, --uid UID nieuw UID voor het gebruikersaccount
-U, --unlock ontgrendel het gebruikersaccount
-v, --add-subuids FIRST-LAST add range of subordinate uids
-V, --del-subuids FIRST-LAST remove range of subordinate uids
-w, --add-subgids FIRST-LAST add range of subordinate gids
-W, --del-subgids FIRST-LAST remove range of subordinate gids
-Z, --selinux-user SEUSER nieuwe koppeling met SELinux-gebruiker voor het
gebruikersaccount
and then it stops.
