ArchiveSW - Grafana Graphing of Archived Data
Using Grafana to create graphs for ArchiveSW.
Installing Grafana
first tests, again quite some learning to do (and refreshing sql queries).
Not sure how grafana will load a simple pi but it puts quite some load on my little ubuntu server build on BRIX N3000/3150. Loads are just peak loads when it get’s the data and builds the graph.
not a problem - I run grafana and influxdb and telegraf on a pi3 and it doesn’t even breathe hard
some have some dashboards to share (I mean screendumps) as to see some inspiration ?
making progress in manipulating the queries and the graphs. Guess once I have made more progress I’ll start over again but … play and learn time
Got stuck on this plugin
the grunt command spits out an error
module.js:550
    throw err;
Error: Cannot find module 'findup-sync'
    at Function.Module._resolveFilename (module.js:548:15)
    at Function.Module._load (module.js:475:25)
    at Module.require (module.js:597:17)
    at require (internal/module.js:11:18)
    at Object.<anonymous> (/usr/lib/nodejs/grunt-cli/bin/grunt:8:14)
    at Module._compile (module.js:653:30)
    at Object.Module._extensions..js (module.js:664:10)
    at Module.load (module.js:566:32)
    at tryModuleLoad (module.js:506:12)
    at Function.Module._load (module.js:498:3)
any idea how to get this running ???
Either it’s not installed or you did not I stall it with the -g option
when you don’t know what you do …
My best guess the original problem is this
yarn install --pure-lockfile
yarn install v1.16.0
[1/4] Resolving packages...
[2/4] Fetching packages...
info fsevents@1.1.3: The platform "linux" is incompatible with this module.
info "fsevents@1.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies...
[4/4] Building fresh packages...
might be that there is already some version installed via your install of nodejs but hell do I know what to do lol
That seems to be the issue. It’s the OS version you have installed.
ubuntu bionic … not so weird these days. I read it is possible that a previous install could mess and there seems to be some option to clean modules and get it system wide and not just related to an instance locally … but this is going way over my cap
We’ll live without that module then, no problem …
I will try to install it later. In what folder did you install grafana?
I went standard and it seems to have dropped in
/var/lib/grafana/
But seems the wind module woke up somehow with all my messing … let me see how to make something with that.
I installed Grafana on the RPi and it works fine. I don’t have time to work with it as I’m tracking down and fixing bugs that have been reported. I’ll be leaving Saigon in 48 hours so I don’t have time for graphs.
Grafana as is works perfect once you learn a few things. Just that extra plugin seems to be buggy … we’ll avoid it for now
I’m running a Grafana/influxdb combo on Ubuntu, on google cloud platform. I think it’s great. And google gives you free credits which work well for smaller instances.
wx.sugartechllc.com:8080
interesting dashboards - FWIW you probably want to think about going to https via LetsEncrypt or the like.
Thanks @vinceskahan. Yes, I’ve been thinking about letsencrypt. Just have to work out how to get it to play well in the Docker container that I have grafana running in.
You might think about a nginx reverse proxy front-ending grafana if you want a public interface. Grafana sure runs great in a container (my grafana and influxdb and mqtt setups are all containerized). Super lightweight.
