Battery history or graph?
i did quite a bit of searching but could not find an answer, so here i am. im in the process of getting everything mounted and what not and have everything figured out so far except one thing. i know i have to be overlooking it somehow but how do i look at battery charge history? Also, is there a way to see if the battery is currently charging? i found the place where i can see current battery level but thats it. one last question, is there a way to get the battery status to show up on the main weather dashboard?
If you turn on the battery card in settings, it will display the current reading and tap it to display a historic graph just like every other sensor measurement.
Settings | Station | [select station] | Advanced | Show Battery Card
aha! ok so i had previously done what you mentioned about the battery card. what i didnt do when on the weather tab was tap the little tempest icon on the top. i was just trying to find the battery read out on the main weather dashboard. thank you for taking the time to reply to my question.
