In settings, do we input the distance from the ground from the top or bottom of the Tempest Weather Station?
I wouldn’t think it would matter significantly if you’re plus or minus six inches…
I use the top mostly because that is where the rain sensor is on the SKY, which did not have a barometric sensor in it. I don’t think the sensitivity of the pressure sensor is accurate enough to determine if you measured to the top or bottom of the Tempest. If you are concerned about it measure to the middle where the passive shield is.
