I have my iPad on the kitchen counter in full screen display to see the current conditions . I would like to click on a reading to get to the graphic display of when and how much (rain) had fallen. As of now you have to be on the default display to access another page of which you can then access the graph.
Home Assistant. Weewx. Many ways of getting there if you roll your own solution.
Not sure what you mean.
@eugenegearty that is a good find. I never thought to test that when the Standard Fullscreen Display Mode was in beta. You are right, graphs are only available in Basic mode.
@cmorello any chance you can make Standard FDM have the same clickable regions for graphs like basic mode has?
Do you think this is might be implemented ?
I certainly hope so. I haven’t tested it on an Android tablet, but I assume it has the same limitation as the iPad version.
This can definitely be added, but let me clear it with everyone before doing so.
I’d also like to see this change implemented.
