Heat Index calculation
What calculation is used to define the current heat index?
I’m using one from NOAA’s site and am getting different results from the same data.
–Sam
Post your formula and let us see what it is doing.
Here is what I use.
// Heat Index Temperature //
// e.Observations.prototype._getHeatIndex
WeatherCalc.calcHeatIndex = function(T, RH) {
	// (air temp in C, humidity)
    var F = _convertCToF(T);
    RH = parseInt(RH, 10);
    if (RH < 40 || F < 80) return T;
    var r = 61 + 1.2 * (F - 68) + .094 * RH,
        s = .5 * (F + r),
        n = 0;
    if (s > 79) {
        if (n = -42.379 + 2.04901523 * F + 10.14333127 * RH - .22475541 * F * RH - 6.83783 * Math.pow(10, -3) * Math.pow(F, 2) - 5.481717 * Math.pow(10, -2) * Math.pow(RH, 2) + 1.22874 * Math.pow(10, -3) * Math.pow(F, 2) * RH + 8.5282 * Math.pow(10, -4) * F * Math.pow(RH, 2) - 1.99 * Math.pow(10, -6) * Math.pow(F, 2) * Math.pow(i, 2), RH <= 13 && F >= 80 && F < 112) {
            var o = (13 - i) / 4,
                l = Math.sqrt((17 - Math.abs(F - 95)) / 17);
            n -= o * l;
        } else if (RH > 85 && F >= 80 && F <= 87) {
            var c = (RH - 85) / 10,
                u = (87 - F) / 5;
            n += c * u;
    } else n = s;
    return _convertFToC(n);
My HeatIndex and WindChill functions. I know the WChill can be optimized, but just running like it is for now.
double Functionsqt::calcHeatIndex(double inTemp, double inWspd) {
    double myHidx = 0.0;
    myHidx = 35.74 + (0.6215 * inTemp) - (35.75 * pow(inWspd,0.16)) + (0.4275 * inTemp * pow(inWspd,0.16));
    return myHidx;
double Functionsqt::calcWindChill(double inTemp, double inHumid) {
    double myWChill = 0.0;
    myWChill = 0.5 * (inTemp + 61.0 + ((inTemp-68.0)*1.2) + (inHumid*0.094));
    if( myWChill >= 80.0 ) {
        myWChill = -42.379 + 2.04901523 * inTemp;
        myWChill = myWChill + 10.14333127 * inHumid;
        myWChill = myWChill - 0.22475541 * inTemp * inHumid;
        myWChill = myWChill - 0.00683783 * inTemp * inTemp;
        myWChill = myWChill - 0.05481717 * inHumid * inHumid;
        myWChill = myWChill + 0.00122874 * inTemp * inTemp * inHumid;
        myWChill = myWChill + 0.00085282 * inTemp * inHumid * inHumid;
        myWChill = myWChill - 0.00000199 * inTemp * inTemp * inHumid * inHumid;
        if( (inHumid < 13.0) && ((inTemp > 80.0) && (inTemp < 112.0) ) ) {
            myWChill = myWChill - ((13.0-inHumid)/4.0)*sqrt((17-fabs(inTemp-95.0))/17.0);
        } else {
            if( (inHumid > 85.0) && ( (inTemp > 80.0) && (inTemp < 87.0) )) {
                myWChill = myWChill + ((inHumid-85.0)/10.0) * ((87.0-inTemp)/5.0);
    return myWChill;
Those are strange formulas. The heat index does not use humidity and the wind chill does not use wind.
Like I said… got it from Noah… I mean NOAA:
https://www.weather.gov/epz/wxcalc_heatindex
https://www.weather.gov/epz/wxcalc_windchill
Hang about. The heat index shows it uses humidity but the formula you posted is using wind.
Ugh… again… looks like I’m transposing the function names…
