Larger size font on screens
I’ve installed the Tempest app on a Fire HD 10 and would like the fonts to be larger to be able to see the numbers from a distance. Would like most to have the first item the largest. We are most interested in the temperature and want to see the temp at a glance.
If the first item was always larger then what ever was most important to a person could be moved to the top of the Card list.
Exactly what I do. Moving the horizontal tabs really helps to see things better.
Yes, being able to adjust font size is needed for ease of use. There are usually 1-3 parameters someone is most interested in so want to see at a glance from a distance.
