Can anyone tell (and maybe update if necessary
) the minimal versions of the operating systems for
A) Android
B) iOS
For iOS the app store mentions iOS9 as minimum
An Android geek will tell you more for that platform.
for App version 2.0 from 11.05.2018 the android manifest.xml shows a minimal version
Android 4.3 JellyBean
And optimized for Android 7.1.2 Nougat
@WFmarketing: is this correct and could you please give some details on what is different in behavior on 4.3 or higher ?
Thanks.
WeatherFlow Smart Weather iOS App v2.09 (current version) requires minimum of iOS 9.0 or higher. This is subject to change when Apple releases new iOS versions…as we don’t know all the technical details on future iOS updates and which older features we can support.
Android 4.3 is minimum requirement (note: not all Android 4.3 devices will be compatible for station setup with WF app as the BLE spec on less common or cheap phones may not be sufficient. BLE is not required for ongoing WF app use…just setup).
