Newbie question about Delat-T
Hi, just installed my Tempest and it seems to be working well. I do have one question that I can’t find an answer to, What is the Delta-T. I know it is change over time but do we know what the parameters are? What is the timeframe? That sort of thing. Thank you for any information on this.
https://weatherflow.github.io/SmartWeather/api/derived-metric-formulas.html
Thank you that was exactly what I was looking for.
Delta T is not over time. In this case the T is temperature. Delta T, is used in agriculture to indicate acceptable conditions for spraying pesticides and fertilizers. It is simply the difference between the air temperature (aka “dry bulb temperature”) and the wet bulb temperature:
