Hiya - looking at this station (mine):
https://swd.weatherflow.com/swd/rest/observations/station/3965?api_key=[blat]
I get…
` {"station_id":3965,"station_name":"Kings Mountain","public_name":"Kings Mountain","latitude":37.44728,"longitude":-122.33502,"timezone":"America/Los_Angeles","elevation":617.2095947265625,"is_public":true,"status":{"status_code":0,"status_message":"SUCCESS"},"station_units":{"units_temp":"f","units_wind":"mph","units_precip":"in","units_pressure":"inhg","units_distance":"mi","units_direction":"cardinal","units_other":"imperial"},"outdoor_keys":["timestamp","air_temperature","barometric_pressure","station_pressure","sea_level_pressure","relative_humidity","precip","precip_accum_last_1hr","precip_accum_local_day","precip_accum_local_yesterday_final","precip_minutes_local_day","precip_minutes_local_yesterday_final","wind_avg","wind_direction","wind_gust","wind_lull","solar_radiation","uv","brightness","lightning_strike_last_epoch","lightning_strike_last_distance","lightning_strike_count","lightning_strike_count_last_3hr","feels_like","heat_index","wind_chill","dew_point","wet_bulb_temperature","delta_t","air_density"],"obs":[{"timestamp":1584201699,"air_temperature":5.5,"barometric_pressure":942.4,"station_pressure":942.4,"sea_level_pressure":1014.9,"relative_humidity":99,"precip":0.008037,"precip_accum_last_1hr":0.784551,"precip_accum_local_day":0.918645,"precip_accum_local_yesterday":0.005842,"precip_accum_local_yesterday_final":0.0,"precip_minutes_local_day":38,"precip_minutes_local_yesterday":1,"precip_minutes_local_yesterday_final":0,"precip_analysis_type_yesterday":1,"wind_avg":4.0,"wind_direction":217,"wind_gust":4.7,"wind_lull":3.3,"solar_radiation":31,"uv":0.16,"brightness":3734,"lightning_strike_last_epoch":1579230839,"lightning_strike_last_distance":10,"lightning_strike_count":0,"lightning_strike_count_last_3hr":0,"feels_like":2.5,"heat_index":5.5,"wind_chill":2.5,"dew_point":5.4,"wet_bulb_temperature":5.4,"delta_t":0.1,"air_density":1.17817}]}`
When looking at both the SW app and the REST result, I do not see the same numbers for precip_accum_local_day where REST is showing 0.92" and SmartWeather is showing 0.04". How do I interpret the value coming back from the REST call, and why is it different than SW?
One guess is that REST is returning in mm instead of inches as that would get the two numbers to match (with rounding), but then why does the pre-amble of the observation in the REST response indicate that units_precip is “in”?
