Sager -> Error: Missing TEMPEST data
When I press the “Sager” tab, I get an error message; “Error: Missing TEMPEST data. Forcast will be regenerated in 60 minutes.”
It has been this way since I put the PICounsel together. Everything else appears to work.
Any thoughts?
Mike
What is your station ID? The error is indicating that no data is available from your Tempest device. Are you sure your Tempest is online, connected to your hub and sending data to the WeatherFlow servers?
here is his station : Tempest
I find it scary that you could find it that quickly from just my post. I’m as sure as I can be that it is online. All the other features of the PIConsole are working, and I usually get an alert to my phone when it goes offline, then again when it comes back online. App also says it’s online.
Can you share the contents of your wfpiconsole.ini file with me in a private message. I can use that to investigate further
I’m having difficulty remembering my PI login credentials. However, while working on this, I noticed that the PI is on my 5G network and the Weatherflow is connected to the 2.4G network on the same router. Could this be the source of the problem?
I doubt it. As long as both the hub and console are connected to the internet there shouldn’t be any issue. There’s just something odd going on with the Tempest data that the console is receiving. Once you send me that file I can take a look into what the issue is
I couldn’t figure out my password, so I reloaded the PI OS and the WF code. While I was at it, I switched the WIFI from -5G to the 2.4Mhz net. Now, I don’t get an error message, it just says “Forcast Unavailable” On the bottom right of the panel, it has “Forecast issued: 09:05”.
Thanks for sharing the .ini file. I’ve managed to track down the issue and will get a new version pushed out within the next few days
