Hi,
What is the difference between Station Elevation and Device Height Above Ground?
Thanks!
Station elevation is your height above sea level on the ground where your station is. Height above ground is how tall your mast is above the ground…
Thanks!! Does the height of the hub above ground matter at all?
Height of the hub does not matter. It does not have any sensors. Its role is a go-between for the sensor device(s) and the WF servers. The hub is what defines a station. The hub is what gets the Station ID.
That makes sense, thank you. I’ve updated my station.
