Things are good here. Easiest install ever with Tempest.
Also reset my Air and Sky units to start everything from scratch with the new hub and to compare to Tempest. So far, measurements are pretty close except for humidity. Air showing 20% higher. I forget how long these things take to calibrate and stabilize.
Mine should be here mid next week in Canada.
My only concern is winter and how well it will hold up in -35c.
I’ve seen specs for the LTO batteries list -50°C for the low end so it should work in that regard.
Both my Air and Sky are hooked up to solar and they went through last winter fine here. I know Tempest is different, but hopefully it will do fine too.
