I just checked my tempest data. It’s 69 degrees here now an my tempest says its 107 with a forecast high of 99. and the values keep changing. Is this a glitch or is my tempest malfunctioning?Station id 24245. checked again an it says its 124 and a forecast high of 112.
it showed a moment of 176F at 3:53pm. What happened?
Looks like your temp sensor might be bad
You can use the support drop down in the top right corner to submit a ticket and we’ll get you taken care of.
I don’t know it just keeps reading high an changing relative temperature and the forecast high for the day
Opened a support ticket. Thank you for the quick response.
