Hello,
does the report intervall changes of the uds report on my tempest station?
Currently the report intervall of my tempest via uds shows 1minute is this all the time or could this be changed by the tempest itself to a lower rate?
Hello,
I’m not sure what uds is, but you could ask support to change the sampling rate. Not sure if they want to do that, but they did it once during an experiment to find a better power saving algorithm. If you mean udp, just adjust the program that you use for handling the udp data.
