UDP Documentation - error in Precipitation Type
Hi,
It seems that the Precipitation Type in the latest UDP API documentation needs a small update.
The documentation says that these: 0 = none, 1 = rain, 2 = hail are the options, but I do sometimes get a value of 3 which occurs when there is heavy rain. Just wanted to mention it.
3 = cats & dogs :slight_smile: :slight_smile:
3 = Build an Ark??? :thinking:
: type mismatch …?!
here is the official reply from David
3 = 1+2
it’s a bitmask
1 = rain
2 = hail
3 = rain + hail ā€˜detected’
2 and 3 are at this moment not actively used for users. Guess technicians are still fine tuning the ā€˜sound’ signatures (that’s my personal theory and maybe not the real case :wink: )
That field is actually a bitmask, where:
1 = 0b01 = rain
2 = 0b10 = hail
which means:
3 = 0b11 = rain & hail
We should make that more clear in the docs. Thanks for pointing that out!
Note, you should consider the ā€œhailā€ bit experimental and use at your own risk.
0b0100 = dogs
0b1000 = cats
0b1100 = cats & dogs :smiley:
0b1111 = turtles
Hate it when it gets to turtles…
nah, 0b1111 = cats & dogs & hail & rain. If you want to be prepared for turtles you should define another bit as in 0b10000 = turtles.
Thanks, that clarifies it. I would say that whenever. I get the combination of 1 & 2, it is always Heavy Rain, and no Hail, so yes that might need some fine tuning.
