UDP info temperature minimum/maximum during the day?
Is it possible to retrieve data on the minimum and maximum temperature recorded during the day with time and temperature? I need that information to get to me via UDP message.
Just collect the temperature data using UDP and maintain your own min/max temps with resets when it makes sense to you.
obligatory weewx answer applies…
Yes. I access it using the API and display it in my graphs such as this:
I loop through the values returned from the API to set the max min etc.
