WS/UDP/REST Data item
How about a message item that shows whether a SKY is in ‘powersave’ mode? Or rather, a ‘output_timing’ field set to 3 or 15? Would make it easier than listening to determine what the timing is.
–Sam
Sam
That is there is the obs_sky
{“serial_number”:“SK-00001878”,“type”:“obs_sky”,“hub_sn”:“HB-00003466”,“obs”:[[1551724844,4,0.00,0.000000,0.00,0.00,0.00,0,3.13,1,0,null,0,15]],“firmware_revision”:41}
In the observation key the last index is either 3 or 15.
In all messages? WS & UDP & REST?
Good catch, Sam. While it is in the UDP packet WeatherFlow is remiss in adding index 12 and 13 to the REST and websocket data. It seems I remember this being brought up months ago.
@dsj Please comment on adding obs_sky index fields 12 and 13 to the REST and websocket data.
Sam,
Here is David’s answer.
