A new version of the WeatherFlow PiConsole is now available: v24.5.1 -> small issue
Just did the update
wfpiconsole stop & update went normal
when I issued a wfpiconsole start it ended with the horrible can’t connect to x server …
a little sudo reboot and all is well again. Just you know, reboot the pi and it will most probably be ok.
Strange! I’ve seen a few reports of this ‘can’t connect to x server’ error, but have never been able to track it down or recreate it. Glad a reboot sorted it out for you!
I updated without issue.
Trying to update from 24.3.1 to 24.5.1…and I get this error:
wfpiconsole
This is a strange looking error. I would try and delete the entire Python virtual environment using
rm -rf ~/wfpiconsole/venv
and then try the update again. It will take longer second time around as it will need to reinstall all the Python packages
@peter
(Running on Rpi400 - Bookworm)
tried updating and keep getting this error …
pi@tempest3:~ $ wfpiconsole update
  [✓] Root user check passed
  [!] Architecture check warning (arm64)
  [✓] OS check passed (Debian GNU/Linux 12 (bookworm))
  [✓] Raspberry Pi check passed (Raspberry Pi 400 Rev 1.0)
  [!] WARNING: unsupported architecture or Raspberry Pi detected
      No support is available for errors encountered while running
      the PiConsole
  Updating WeatherFlow PiConsole
  [✓] Checking for updated packages
  [i] No updated packages found
  [i] WeatherFlow PiConsole dependency checks...
  [✓] Checking for git
  [✓] Checking for curl
  [i] Checking for rng-tools (will be installed)
  [✓] Checking for build-essential
  [✓] Checking for python3-dev
  [✓] Checking for python3-pip
  [✓] Checking for python3-setuptools
  [✓] Checking for libssl-dev
  [✓] Checking for libffi-dev
  [✓] Checking for libatlas-base-dev
  [✓] Checking for libopenblas-dev
  [✓] Checking for jq
  [i] Installing Python virtual environment... already exists
  [i] Updating WeatherFlow PiConsole Python modules...
  [✓] Updating Python package manager
  [✓] Kivy Python library installation check
  [i] Latest version of WeatherFlow PiConsole: v24.5.1
  [i] Installed version of WeatherFlow PiConsole: v23.11.1
  [✗] Updating WeatherFlow PiConsole to v24.5.1
  Error: Unable to update WeatherFlow PiConsole
 fatal: unknown index entry format 0xffff0000
Had to Google this: github - git - fatal: Unknown index entry format - Stack Overflow
Try running
rm -f ~/wfpiconsole/.git/index
cd ~/wfpiconsole/
git reset
and then try updating again
@peter
BINGO! –
Thanks again for all your work on this wonderful project.
working perfectly again… :slight_smile:
Having an issue with my install. I am installing a PiConsole in our Emergency Operations Center, hooked to an HDMI Matrix that feeds displays throughout the building. When I hook my Pi up to a regular monitor in my office, everything works as expected. However when I hook the Pi up to the Matrix, it boots to a Raspberry Pi GUI Login screen, and not Pi Console. It does this every time. Any idea why it would behave this way?
It probably thinks the HDMI matrix is a second monitor and your os is configured to run the console on the other monitor. Just a guess. If you can hook up both HDMI devices you’ll perhaps see piconsole on the regular monitor.
Not sure exactly what the problem is here, but it is likely related to the Pi and the HDMI matrix rather than the PiConsole. Consider having a look at the configuration options under Boot / auto login. There are a number of options there that control whether the Pi automatically logs in, or requires a username/password to be entered
Thanks. I’ll give that a try.
A new version just came out yesterday v25.9.1. Update went smoothly.
Question: For my “wfpiconsole” using v23.3.1 on Buster O/S. . .if I “were” to upgrade to v25.9.1. . .would I have to install the latest Pi4 operating system. . .OR. . .would the Pi4 console do that for me?
I’ve had my wfpiconsole (Pi4) on v23.3.1 (Buster) since 03/03/2023. .. and it’s been working Great ever since then. I kinda figure that if it works to my satisfaction. . .which it Does. . .then I shouldn’t “horse-around” with trying install an update?
Yes, you would have to install the latest OS yourself by imaging a new SD card
The changes since the version you are running on a pretty minimal. Mostly bug fixes rather than new features, so if you’re happy, you can probably stay where you are. That being said, I am working on an improve forecast panel that’ll display the next 12 hour forecast, a 5 day forecast, as well as the closest METAR and TAF reports. If you want this, you might want to think about upgrading
