Error starting wfpiconsole - “Couldn’t connect to X server”
wfpiconsole v23.3.1
Bullseye desktop 64-bit
This wfpiconsole was working okay with Buster.
Then I stored it away for almost 2 years.
Went to use it today, would not work.
So reloaded RP4 with Bullseye, and followed installation instructions.
Am now stuck with this error - and it will not run.
I’m back.
Am now running the 32-bit Bullseye and still getting “Couldn’t connect to X server”
UPDATE:
found that problem only occurs when starting weatherflowconsole in a SSH session.
enabled autostart and rebooted - and no more problem - comes up okay now.
