Is there a document that lists the available commands?
How do I specify the weather station (I have several) that I want Alexa to ask for weather info?
Erik helped me out!
Here are all the commands that work with Alexa. If you have more than one station, then you will need to specify that station in your command. So, for example: “Alexa, ask WeatherFlow the temperature at [2nd home station name]”.
Copy of Alexa Phrases.pdf (73.3 KB)
